I purchased a complete trunk floor from Goodmark for my 71. I went to bolt it up to the frame, and the holes don't even come close to lining up. I pulled it back out and took some measurements and it appears the width between the two cage nuts closer to the wheel wells are a full 1/2 inch short. I measured my frame, and it measures exactly 43 1/2" from center hole to center hole, like the manual says. Then measured the floor, and it is a hair less than 43" from center to center cage nut. I mean, there is no way there is enough wiggle room in the cage nuts to make that up. Stumped.
Has anyone experience this issue before?
