car details: 71 chevelle, LM7 N/A with 400hp at crank, EV1 injectors holley term X, fuel pump NOT managed by holley - on a switch in the dash, Aeromotive 340gph stealth pump w/ only about 200mi on it
the scenario: driving in my chevelle the other day the wire from my fuel pump relay on pin 87 to pump power started to burn out, and the relay itself was hot hot hot - too hot to almost touch. recently i put 42lb Ev1s in with the holley term X but did not touch the fuel pump - its on a switch and not managed by the termX
the pump is grounded to a fuse block and always has been, with no known prior issues
what i have done so far: swapped the relay out. crimped and installed a new wire from the 87 pin on the relay. i have also moved the ground wire to a new location on a different fuse block. i also cleaned out the fuel filter.
i am still feeling like the relay is getting hotter than normal/should.
the need: im trying to track down how to test current / amp draw on my fuel pump relay with a multimeter to see if the pump is pulling more than 15A or so which is what Aeromotive recommended. my multimeter is a Bosch Fix 7665 and has a 10A unfused port and a 200mA Fused port. i have scoured the internet on how test amp draw and everything i am saying is over 10A and i will blow my multimeter a part.
thoughts:
thoughts:
- how can i test the amperage the fuel pump is pulling being that it over the 10A max on mine?
- should i try to ground the pump directly to the chassis
