Frame Question
924 views 5 replies 3 participants last post by  htm
#1 · (Edited)
Hi guys, I need some help, after ****** around on the street I had a liitle accident :( well not so little after all kinda hit on the right side messed up my right fender, bumper, rad support, all was fixed untill I was washing it and notice the right wheel was set back after investagating a little further found the frame was bent right in front of the dog ear pulled out very nice but since then the ride hieght has been off low on the right side today i spent time with one of our body techs and put it on the fame machine (shark measuring system) since my 67 was not in the data base we just took some general measurements and it appears off but visual inspection and what the machine said just did not seem correct so we went to the tape measure way still inconclusvie, now they think its in the rear suspenion,,, not swaped springs side to side same results, so after this long post I am looking for advise or if anyone knows a good shop that deals with frames in the northeastern PA area or northen NJ. Thanks
#3 ·
I have the measurements in the Shop manual, I have no way of entering them in the measuring system, normally the system pulls all the specs and tells you were to put the sensors, so thats why we just took general measurments and compared side to side the torque box seemed good but the front part of the frame had hieght differances the thing is the computer shows the side to side frame at the rad support mounting off 20 mm whichs is approx 1 to 1 1/4 this would be visable to the eye and its not off that much that what has us all baffled ???? Thanks for responding
