Here's a fun one. One day driving to work (yes, I daily drive my Chevelle) the engine just shut off. I coasted to a parking spot and it re-started immediately. A dozen yards later it did the same thing. Ended up doing that maybe six or so times that day, with no pattern (bumps, steering angle, etc.). That weekend I jiggled every wire and played with the ignition switch, HEI, shifter, fuse box, etc. I used my rubber mallet and tapped all around. I let it get hot. Nothing.
So I figured I would drive and observe. Test drive around the neighborhood and everything was normal. I drove to work the next day and it was fine. I drove home and got into the garage and turned off the ignition. The car kept running. The only way I could shut it off was to pull the power wire from the coil.
Does this point to the ignition switch?
