It's obviously been too long since I've built a SBC motor!! I thought the #1 piston fires when the timing marks on the cam gear and crank gear are aligned, but it appears that that's actually TDC on the exhaust stroke and the spark goes to #1 when the cam mark is actually at the top on the gear. Is this right?? If not I can't figure out how to change it!! Also, just to double check, is the forward most lifter on #1 exhaust or intake??
Thanks!!
Thanks!!
