I have been a mechanic for over 20 years ,, and just built my 440 Dodge engine which has a hex drive shaft for the oil pump drive as does Ford ,, Chevy has a drive that will accept a flat blade screw driver like Blown 406 says ,, simple holding down on distributor while someone cranks engine will work fine ,, there are several ways to bring disributor down fully ,, if you are useing store bought ready made wires you may want to look in shop book and locate #1 on cap and point rotor to that position ,, once you have droped dist. in and have to crank it to make it fully drop ,, dont worry nothing has changed with your timming ,, just remember to mark were your #1 was
