DECODE T12 BEHIND THE SMALL BLOCK CONV 1
1 reading
5.3K views 5 replies 4 participants last post by  DaleM
Hi i need help decoding these numbers. Hopefully im right but there questions please help. The Motor is a 1968 327 small block.
18Z 157246 , T05I5EC In The Front Head Stamp Area.
Back, of Motor
GM 3914660
T12 CONV 1
Please help and thank you so much. I'm learning as I go. I'm new to this. Thank you once again
#4 ·
18Z 157246 = Chevrolet, 1968, Fremont Assembly plant, 157246 = Sequence number. This string is also known as the CONVIN. It will be stamped in all locations containing the ConVin AKA partial VIN.
T05I5EC = Tonawanda Engine Plant, May, 15, EC= L30 327 4BBL, 275HP W/ POWERGLIDE TRANS
GM 3914660 Block Casting number = 2 bolt 1968 327
T12 = You got me, that's not the block casting date. Might be the mold number.
CONV 1 = ?
#5 ·
Thank you so much man your fast. I still can't find those numbers either T12. Thank you at least i got a good start with the block 275. I think with a turned motor and crank, re did the heads, new cam, new intake, new timing chain, new 4 bqrrel AVS2, new 700r trans, heads and mufflers, with new almost everything i believe if i time it right i should push 350-370. I hope. Too many new parts all match so its a smooth machine monster. Whatcha think?
