Cost of 200r4 swap? $2500?
4.6K views 7 replies 7 participants last post by  edhale
I've been considering adding overdrive to my 72 Cutlass because I drive the car everyday and a decent share of it on the freeway. I've read up on all the posts, and it looks like the 200r4 is what I want for my stock 350. I talked to a reputable shop and they quoted me about $2500 all said and done out the door, saving only about $100 if I brought in a used tranny from say a Monte or something as opposed to buying one from them.
I've done most of my suspension upgrades myself, as well as my interior, but the transmission is something I think I need to leave to professionals. From the posts I've read, I figured this would cost me less than $2K... is that a pipe dream? :(
Thanks in advance,
Riley
#2 ·
That does sound pricy but if the trans is very well built, they are doing removal/install, and setting up shift points etc that may not be a bad price. If its a column shift car they needs to do some mods to the shifter linkage im sure. Are they offering a warrenty?
#3 ·
if they are saying $2400 if u buy a used tranny yourself thats outragous. Putting the tranny in is easy, and u could do it yourself, its only 6 bolts on the bellhousing and bolting in the crossmember, and bolt up the torque converter. I assume the driveshaft would need cut? that shouldnt cost that much, and the linkage would probably swap over easyily from a junk yard monte carlo. i changed the 200r4 in my 85 monte carlo ss and had never done it before, it was easier then i thought. Id suggest just pulling a tranny and linkage from a monte carlo. and putting it in yourself. Prob could do it for under $300. I got a 200r4 from a guy for $200, put a $75 trans go shift kit in, and it lived behind my 400hp 350 for 2 years when i sold the car.
#5 ·
They told me "turn key" and said it's "rebuilding the 2004r to new, new converter, TV cable kit, lock up wiring kit, crossmember, shifter kit, labor for installing, speed o gears, dipstick,inspection cover, fluid."
The thought of doing it myself is always more fun than actually doing it, and I would like to save money and learn, but don't currently have garage space to work out and am more than a bit cautious because I know nothing about transmissions.
Also, if any Socal guys have recommendations of somebody that could do it for less, my ears are definitely open!
#7 ·
i put a 700r4 in my Monte for the cost of a case of ATF and filter. oh, and the $5 for the qjet tv cable mount off a mid 80's Cutlass with a 307.
of course, i had the trans laying around from a 92 Caprice cop car i parted out, and i cut the driveshaft myself (amazingly easy, actually, and haven't had any bad vibes from it in 3 years).
the crossmember slid right back to the TH400 location, the speedo cable and cooler lines hooked right up, and the column shifter work perfect and goes into all gears, but i had to adjust the neutral switch a bit so it worked properly.
it is worth noting that in my car- aero package of a brick, weighs 4000 pounds, has 2.73 gears and 28" tall tires, and the gutless stock 350- i actually lost some mpg for all my efforts. but it is slightly quieter at 80mph, and the steep first gear gives me the confidence to pull out in traffic.
Riley,
I was quoted $2500 out the door from Art Carr in Huntington Beach (probably charging more because of the Overhaulin' and Hot Rod Magazine connections).
I was also quoted $1750 out the door from a local shop here in Mission Viejo who has rebuilt a late model trans for me. Very clean and organized shop. Lifetime warranty on the one they rebuilt for me and free fluid and filter change every 12000 miles.
