Hi guys, so im new here. Im working on a project 67 chevelle. I did a search and didn't really come up with too much. I will try and give as much info as possible, and i will follow up with the solution when the time comes. So i have a 67 chevelle. I swapped a 350 with turbo 350tranny which came out of a 69 chevelle my brother bought last year. He had a built drive train for it already so he gave me this one. He drove the car home about an hour and for a couple days after purchasing with no issues , before he did his swap. The engine sat in my garage for about 4 months before i dropped it in. Went to fire and got nothing. We dont know the internals but its a 350 (010 block) with edelbrock performer intake, holley 650 carb, hei distributor. I put new delco plugs, gapped at .045, new moroso wires and hedman headers and changed oil and filter, and put mini starter (oem) Aside from that i didn't touch the motor itself. I haven't wired the car up yet, i just wanted to fire the motor first before doing all that. So we hooked up a good battery with cables to a good ground, and the starter. A jumper to the positive on the distributor and one to jump starter solenoid. Ran a hose from fuel pump to a jerry can of gas. Very basic. Starter cranks engine over. Tested all connections. Get battery voltage at starter and distributor, spark at plugs(although i think its a touch weak), fuel squirts into the carb when i give i hit throttle (with good pressure at the line going into the carb) , new clean fuel filter. Distributor was not touched so timing shouldnt have changed. Pulled cap and can see rotor spinning. Olugs wires aee in correct order. The thing was fine when he pulled it from his car and it wants to fire up but just wont. we've been trying to figure it out for a few days. If anyone has any ideas or has been through this before i would really appreciate it. Thanks
