Ok,then the 8 deg base should be ok since it ran ok temp wise last yr at that same base timing setting.
But i will say this,your motor seems to be very sensitive to timing temp wise but it should not be that sensitive to no vac adv unless you do in fact have a mild perf cam . Then in that case whats likely happening is with base timing at only 8 deg & needs to be approx 16-18 deg thats 8 to 10 deg retarded making the motor much more sensitive to loosing some timing from a non workng vac adv at idle/lower enoigne speeds. Now with the vac adv not working that took away at least 10 more deg timing if not more like 15+ & along with the retartded base timing that would definately make it run considerably hotter. But if you were for ex running 16-18 deg base timing the motor would have still lost the timing at idle from the non working vac adv but it would still have 18 deg base timing insted of only 8 being 8-10 deg more retartded making the motor more sensitive to loosing the vac adv at idle which is what makes me think you have an aftermarket cam in your motor.
Think about this,just about nobody/no engine builder buys a stock GM way over priced cam for a rbld. 999 out of 1,000 of these muscle car motors that were rblt in the past 15-20+ yrs got an aftermakret crane(in the past prior to going out of buisness)/comp/lunati/etc cam and i think your motor very likely has an aftermarket perf cam and you dont know it. Most people/engine rebuilders use the term loosly "i put a stock cam or stock type cam in the motor" when rblt but its just about never a true original stock GM replacement cam & even mild aftermarket perf cams need approx 16-18 deg base timing for best results/perf. Maybe once in a while it could be a blueprint cam from crane in the past but comps repl cams for muscle car motors state in the catalog that they are a little hotter for better perf with more duration & tighter LSA's and of those that i have installed they all neede approx 16-18 deg base timing too.
But if you get the correct vac adv hooke to full int vacuum the additionaltiming from tha will likely get the motor temps back down a few deg.
Well,enough of that.
Mighty vac is a hand held/operated vacuum pump that has a gauge on it which you can monitor to see at what vacuum lvl the vac adv starts to activate.
You need to take an idle vacuum reading and then simply get a vac adv thats full activated at approx 2" below the lowest idle vacuum to ensure its always full activated for stable idle & lowe speed engine operation.
If the vac adv on you old dist is of the same design and did work ok then maybe you could simply sawap it to your new dist .
Also,if it still runs hotter then it did last yr after getting vac adv working properly then try a new t-stat,they can go bad & or get partially stuck (not opening fully) at any time esp when sitting in off season for 3,4,5, months of non use then firing up the motor for the new cruise season .
Scott
