I'm giving the small block thing a try with my 355. My AFR 195 Eliminator's should be arriving tomorrow. What is a good cam to get my Chevelle into the 11's or very low 12's. Also if they can work with the springs that come on the heads that'll be great. See info below -
Intake Valve, 2.050" standard length AFR #7204
Exhaust Valve, 1.600" standard length AFR #7219
1.290" OD Hydraulic dual valve spring w/ dampener, 135lbs on seat, .600" maximum lift
Car has a turbo 350 with a 4000 stall (stall at 4400 behind my BBC), 4:10 gears with MT ET streets measuring 28X11.5. I also have power brakes. Engine has approximately 10.5:1 compression.
