Last night, a friend and I spent about an hour and a half trying to manually (foot on the brake pedal, crack open the bleeder valve) bleed the front disk brakes on my 69 Chevelle. Just when it looked like the air bubbles were subsiding, another round starts in. We finally concluded that air must be getting pulled into the system from someplace (?), so I pulled off the new master cylinder with the intention of returning it for another today. One thing I'm concerned about though is the metering valve located next to the master cyl. I have disassembled, cleaned and reassembled it. There is a rubber seal in the bore at the back of the valve and the rubber cover that snaps over the shaft (button) is cracked and no longer usable. Could air be getting sucked in past this seal? Would a missing rubber cover be allowing air in? I'm at the point now where I will get some sort of thresded fitting to by-pass this valve altogether as it doesn't have a very important function anyway. Can anyone help me out with this? I've got a cruise night on Saturday and a show in a couple of weeks and would sure appreciate any insights!
Thanks,
Rich
Thanks,
Rich
