Hi J.R.
We need more info to be able to help with your lack of or "no power."
We need to know what you intend to use the car for: Daily driver/cruiser, street/strip...
Next, what are the specs of your engine and how it's tuned.
Compression? Heads and valve size? Complete cam specs? intake manifold? Carb? Exhaust?
What distributor do you have and what do you have the timing set at?
Base timing (at idle) and total timing (the max amount of timing ya get when revved up with vac advance unplugged), if using vacuum advance, is it hooked to ported vac or full manifold vacuum?
Also Trans (stick or auto, converter)? Rear end gear ratio?
Also give a good explanation of what you are experiencing when you say "no power." Does it bog, just feel weak or run out of power at a low RPM? Please be specific!
