I've read this entire thread, and I must admit that I'm trying to wrap my brain around this entire issue you're having. Maybe for me it's the lack of visual aids such as more revealing pictures. I don't know.
I've purchased these same spindles, but directly from Chassis Works, and I think I only waited two weeks for delivery. But I haven't tried to install them yet. For clarification, please let me know if I'm getting this right, ( I'm not sure that I am)....
Is the fact that these spindles being made of aluminum, and therefore being thicker where the ball joint taper inserts into, creating the need for a ball joint with a longer threaded area? Am I reading you right? And what about these special steering arms that Chassis Works sells for these spindles? Are you using these too? And have you noticed any problems with the steering arms as well????...My understanding is that these special steering arms are supposed to correct, (or prevent) the bumpsteer issue that these spindles would otherwise create if the factory stock type steering arms were used with them....
https://www.cachassisworks.com/p-29...949-chevelle-64-72-a-body-bumpsteer-corrected-steering-arm-billet-aluminum.aspx
I guess I'm getting a little confused about this, because in certain parts of some of your posts in this thread, it sounds to me that you might be implying that the control arms were/are part of the problem, but I had originally thought that it's actually the extra bulk and thickness of the aluminum spindle that is causing the issues you've had. Correct? If I'm getting this correct, then would a special ball joint offering more thread engagement be the solution to the problem? I would be inclined to write or call Chassis Works to complain about this issue since I also have purchased these same spindles as you have, and therefore I am also a customer of theirs. However before I can contact them to complain about this, I need to fully comprehend the problem at hand, as well as what the most logical solution would be. Please explain if you would. Thanks in advance.
