I saw this thread regarding the merits of hot rodding a 307, the topic comes up every now and then, and people are usually either all for or completely against the idea. I did a modest 307 build-up for one of my cars, and would like to share my results.
It seems like there are scads of 307’s everywhere. Personally, I had one in an old car, and one sitting in my shop under some shelving. They both were oil users. Do I just pull fasteners off of the one on the floor and haul it in for scrap? I also had recently pulled a 350 from a C10 and it was sitting there on the shop floor also. Hmmm, I thought, bending over the 307 and looking at block code on the back, a guy could build a 307 with 1 hp / cubic inch for peppy street fun, and the 350 with 1 hp / cubic inch for another car for real high performance usage! I stood straight up, and hit my head on the bottom-most shelf. I staggered back a bit in pain and was seeing stars. I heard a voice coming from the 350, and I saw a little angel sitting on it. He said “good guys always build 350’s and only a loser would waste time on a 307”. I heard a second, gruffer voice coming from the 307, and there was a little devil sitting there on that engine! He said “you should build this 307, Ford 302’s run good, you could make this engine do just as well! The little angel retorted: “The ford 302 has the magic 4 inch bore, the 307 is nothing more than a stroked 283!” Next I heard the little devil humming a tune that sounded like an old Meatloaf song, and then he softly sang: “now dooon’t beee saaad, cause two-eighty-threes ain’t bad….”
Back to reality, there is some information out there on dyno tests of small engines like 318 mopars and 305/307 Chevys. Here is a link to an engine build a magazine did with a 307. With regular performance parts they achieved 315 HP / 330 ft/lbs:
307 Chevy Dyno Test - Super Chevy Magazine
Compare that torque rating to a 300 horse 350 factory engine from say, 1969. Chevy claimed 380 ft/lb. So you have 2 engines at about 300 horsepower, except one has a 50 ft/lb advantage over the other. Clearly the 350 would provide a better E.T., all else being the same.
I could not pull the trigger on a 307 hop-up until I acquired a 72 El Camino in 2011. The Camino was a 307 three on the tree basic truck, and supposedly the 70,000 mile odometer reading was accurate. I did not take too much stock in this claim, but after driving it for 1800 miles, the oil level was still not a quart low. I performance tested it with my G-Tech and the results were an 18.2 second quarter mile at 71 miles an hour. It could smoke the one tire easily but had a sluggish top end.
I needed to pull the engine to fix a leaky rear seal and to replace broken motor mounts. I was also swapping out the 3 speed Saginaw for a 4 speed Saginaw. I decided I was actually going to hop this engine up if I could avoid any pricey machine work. I was pleased to find the cylinder walls had only the lightest ridge, and the factory nylon timing gear was still in residence. Perhaps this really was a 70,000 mile engine? It would have been a pity to junk a smallblock that was in this good of condition.
To keep this a low cost, fun, budget build, I looked for deals and accumulated parts. The heads were a lucky find from craigslist. Instead of doing the 305 head swap you often read about, I found someone who had a machine shop-fresh set of 1990 Camaro FI heads. These have the bigger 1.94 intakes and smaller combustion chambers, and new valve springs were also installed. But the owner decided to go with a higher performance type of head, and wanted to sell these Camaro heads for $300. Score!
New rings and bearings, a .450 lift Summit cam and lifter kit, a used aluminum intake, used Edelbrock carb, and new headers were also purchased. I ordered a 2 ½” dual exhaust system to finish up the build.
So I did everything you are supposed to do when hopping up an engine. 4 barrel, heads with bigger valves and more compression, bigger cam, headers. Plus I was replacing the three on a tree with a four on the floor. The Camino even had a 3:36 rearend, albeit it was an open differential. One would think a big change in performance was imminent. After getting everything in good tune I was pleased that my truck could smoke the tires all the way through second gear, and a little more squeal in third. Dumping the clutch from a dead stop resulted in serious wheel hop, and easing out of the hole and then stepping down was wheel spin city. So all my testing was limited to taking off from a dead stop by gradually pressing down the accelerator till I could hold it all the way to the wall and still have forward progress.
The best quarter mile time I could achieve using my G-Tech was 16.4 seconds at 87 mph. You can see by the mph that with traction, the truck should have been into the 15’s. I would have preferred a 90 mph trap speed because then I could at least say it was capable of 15 flat. So there you have it. All those performance parts resulted in a quarter jaunt of what a 4 barrel factory 350 with headers would probably provide.
If you have a car with a decent 307, and you want a little more “umph”, some reasonably chosen performance parts can boost that little engine up to 327 or 350 status easily. This is contingent of course on having a better set of heads available. I thoroughly enjoy trying to coax extra power out of my vehicles as long as it’s not cost-prohibitive. It was a fun project. Really really glad I did not start with a worn out 307 and then spent a thousand bucks at a machine shop!
