My 66 has a loud rattle that seems to be coming from behind the dash when I hit speeds between 55 and 60 MPH; normally happens when I’m heavy on the throttle, and most always at the same speed. What seems so strange is that if you ease up off of the throttle the rattle will slowly fade away, at which point I can speed up and everything seems normal; it won’t come back until I slow down considerably or come to a stop and then accelerate again. This isn’t an intermittent problem; it happens almost every time I get up to speed under normal to heavy acceleration. If I baby it and accelerate slowly I can keep it from happening, but that's not how I drive. The person that I bought the car from was told that it was the torque converter, but the two transmission specialists that I've taken for a ride tell me that there is no way that the noise is coming from the TC or the trans (700R4). I have a hard time believing that it is something like a cracked flexplate because it is too specifically tied to the speed of the car and not the load on the engine (327). It sure sounds like it’s coming from behind the dash, but I can’t think of anything back there that that could cause such a racket (except for the speedometer cable). The dash does not vibrate or feel like anything is hitting it when the rattle is present, but I’m not sure that it isn’t something hitting the firewall.
I think I’ll disconnect the speedo at the trans and see if it has any effect at all.
Let me know if anyone has any other suggestions.
Thanks,
Bryan
Thanks,
Bryan
