Hi Bill,
It's been a long time but & used to use the long style clutch in my Vega both with a Lenco & with a Clutchflite.
I could adjust the spring pressure for launch & add counterweight to keep it hooked down track.
Never really messed with the springs once I got it set but did use different counterweight for different conditions or it would smoke the sucker going int 4th gear with the lenco & the clutchflite was especially hard on it on the 2-3 shift without a bunch of counterweight.
I can't say what is best today as this was many years ago.
We ran essentially the same thing in the TAD but with three discs instead of just one & you could control the amount of "slip" with both spring on launch & counterweight downtrack.
At the time it was the only type of clutch I could keep in the vega but like everthing else I am sure they have come a long way over the years.
I tried a long with counterweight when I ran a 4 speed but I could never get it to want to shift as the counter weight added to the clutch & pedal pressure. Ended up with very little counterweight & more spring.
Had the best luck with a diaphram,,don't even remember who's it was
Again, this is "old school" stuff
