71 dash color change
1.3K views 5 replies 6 participants last post by  Elviss 1971
i have a blue dash now, wanted to change it to black-i fig along with the normal prep, a plastic primer might be a good idea-is the SEM a good choice for painting it-inside the glove box is gonna be hard with blowback, but i guess its not that bad, and a lot of taping
#3 ·
I've got 2 SEM products at home that seem to work great together on hard plastic. The first is a spray on cleaner ( plastic prep might be the name) and the second is Sand Free which ,according to the label, "opens the pores" allowing the color to adhere. I originally did my dash 12-15 years ago and it still looks good.
#4 ·
yep the SEM plastic prep. works well with the dash, as well as kick panels and rear arm rests. SEM 15013 is the black i used after reading an earlier post of yours and it came out perfect. thanks
also if you're doing alot of spray painting i recommend a clip on gun attachment for the spray can, they are sweet.
#5 ·
I've used SEM's Landau black with great results. Only thing I can complain about is the fact the stuff is $12 a can. But it is sure worth it.
