Hi all, been away for a bit but back on this project with a question. 69 Malibu power top convertible, factory A/C. The original 307/Powerglide has been swapped for a L98 350 w/ HEI,/700r4, and am in the process of changing the stock fuel gauge/idiot light cluster for an aftermarket replica SS tach/oil pressure/temp/fuel and amp cluster. I also plan on adding Holley sniper EFI with an in tank fuel pump I have after the new drivetrain is dialed in. In anticipation of adding the Sniper and its additional current requirements, I've installed a Tuff Stuff 100 amp externally regulated alternator and electronic voltage regulator. This was chosen over a one wire set up to keep the amp gauge function and the engine bay's original look. My dilemma is with the amp meter. I'm told it won't survive the extra amps, American Autowire's upgrade harness doesn't have a provision for it.
Looking at the meter, it doesn't look like the old traditional meters I'm used to that carry full current, the wires running to it from the harness look like 16-18 gauge, no way they would handle any type of load. So I'm wondering if this is a true amp gauge or some type of volt meter that reads as a quasi amp meter? As it only reads plus or minus and the small gauge wiring I'm thinking it should be OK to use with the higher output alternator. I'd also like to replace the under dash wiring harness with an OE type that would retain the amp meter function. Anyone else been down this road or have any experience with this? Thanks in advance.
