I have sold off most of my 468 parts, including the shortblock, and am contemplating selling my cylinder heads as well (Dart 325's). I have pretty much decided that I am going to do a Dart based motor and am wanting to stick with a 9.8" deck block for header purposes and stock appearance. I am wanting to build an engine to run on e85. Here is what I have determined so far.
*Dart Big M block 9.8" deck, 4.560 bore
*Eagle rotating assembly 4340 crank, rods, srp pistons (12.8:1)
*Reusing my moroso oil pan
*E85 fuel, not sure if I can support the power with a 4150 or a dominator might be necessary
*Intake I currently have now is a 4150 Victor 454R
*Solid roller cam (no specs yet)
My goals for this engine are:
*7000 rpm
*easy 9 second et's
*run on e85
Here are my questions:
What cylinder heads should I run? I currently have the Dart 325's but assume that they will not support the cubes and compression on a 555. I have been looking at the AFR 335's and the Dart 345's.
Camshaft: I have no clue on where the specs should be. It will be driven on the street but that has no bearing on what it should have to do. It will be a race car that I drive on the street. I was thinking in the 280 range at .050 maybe a little less and in the mid to high .700's for lift, not sure on lsa, I am not a cam designer...thats where you guys come in
Carburetor: I have a prosystems 4150 1000 cfm hp. Like stated above, I want to run the e85 fuel, and am worried about that carb keeping up. I emailed Patrick about it and he recommended the e85 Dominator. Only problem with this is I would lose my ability to run an air cleaner which I really don't want to do.
The rest of the combo will be in a 83 Monte Carlo SS that was 3437 race ready last year with a stock block, so I figure I will pick up 100lbs or so. I have 2" x 3.5" collector headers and two different exhaust systems to use (collector extensions with bullets and 3.5" x pipe with ultraflo's).
My fuel system consists of a Magnafuel 275 fuel pump with -8an line and magnafuel regulator.
I have both a t400 and a powerglide, and have an 8" ptc converter that I used last year.
28x10.5 slicks with 4.11 gear currently.
I know this is a loaded question but I really need some insight on cam, heads, carb. What type of power could this engine produce and et's?
Thanks for your help TC...Ross
*7000 rpm
*easy 9 second et's
*run on e85
