HI Bob,
Thanks for the post but I think Phil may need some help with this from someone that can actually measure his deal.
Phil, I highly doubt you are going to have a pushrod length problem given your parts & stock ones will probably work just fine as long as they are the right diameter but it is always a good idea to check the length.
As was suggested, just measure the guideplate or compare it to a 5/16th or 3/8th wrench.
I do not use the little pushrod checkers sold by Manley, don't like them.
I haven't figured out what they were designed to be accurate with but it doesn't seem to be most aftermarket rockers.
I always check the pattern on the valve with an adjustable pushrod.
Most of the rest of this is for Todd if he is still out there,,,& of course anyone else that cares to comment or get bored by a long post,,,
Now,,, as to the diameter of pushrods,,, I have posted most of this before but here it is again just for lack of anything better to do this evening
for most applications a 3/8" .080 wall is just fine but,, with any serious roller application with real springs you might be surprised at what works.
Consider the pushrod as a piece of spring steel complete with harmonics & resonant frequencies for a moment.
Now consider what happens when your spring goes through it's harmonics & dances clear off the head & retainer.
And at some point in your rpm range I can just about guarantee it does.
Also, a 600lb spring has over 1000lbs on that little piece of spring steel.
All pushrods deflect & rats are one of the worst offenders with their goofy angles.
A pushrod cannot be to stiff to control valve movement.
If you consider it as a piece of spring steel you can see why the thick double taper ones are the pushrods of choice in most professional hi rpm applications.
Once you see a spintron test & what spring & pushrods do you may never want to build another engine
It gets ugly!!
I don't think you can get the valvetrain too stiff.
As an example, we went from a very good quality 3/8 .080 wall pushrod to 7/16 .120 double taper & picked up about 10 to 12HP with no other changes on an 18 deg small block deal & the torque curve got a bit smoother above about 8200 with a lot less of the cute little dips & spikes in the torque curve we were blaming on the springs.
And these were very short pushrods,
(Tall lifter, shaft rocker)
Within reason, I could basically care less about pushrod weight & have seen more power in the same engine with pushrods that were probably twice as heavy as the ones that came out.
It has been proven that within reason weight on the cam side of the valvetrain is not real important especially at the expense of rigidity.
All that aside, we normally use 5/16" or 3/8" in SB & 3/8's in rats in almost all engines & don't seem to see any problems. (that we know of
But,,, I am starting to look at this more after seeing what the big pushrods did in this little 332" engine considering they were only about 6.5" long
12 HP is a lot for such a simple part & yes we went back to the 3/8's just to verify it was the pushrod.
Of course, this deal runs well over 9000 rpm & does have a bit of spring pressure
