12 Bolt Posi carrier Question ??
1.7K views 8 replies 4 participants last post by  CDN SS
I have a 12 Bolt 4 series Posi carrier ...empty ..........is there any reason I cant put any Chevy 12 bolt posi parts / spiders etc in this case ......just thought I would dbl check
#6 ·
Any of the 12 bolt Eaton Posi parts will fit in it. You can use the parts from a 2 or 3 series, or a 12 bolt truck Eaton Posi. It must be the Eaton Posi. The Eaton Truetrac and Eaton Governor Lock parts will not work. You can not mix the gears from the old style and new style Eaton Posi.
#4 ·
Bill ,lets verify just which carrier you do have .
Would you post the casting numbers?[/QUOTE
Not in front of me .............the carrier was in my 66 Chevelle with 12 bolt rear original to my car ..its a car 12 bolt carrier
#2 ·
The cases are all the same. Series 3 parts will bolt right in.
