10 bolt to 12 bolt swap, u joint doesn't fit
1 reading
37K views 14 replies 8 participants last post by  driveshaft-texas
I just put a 12 bolt rear in my 66 Chevelle but it has the larger yoke on the rear. My driveshaft's u joint no longer fits. Was there a special driveshaft for 12 bolt rears :confused:
I did a search on the forum and heard of a cross over u joint mentioned. Where can I buy one of these? Anyone have a part number or a source for these?
Thanks,
Bob
#3 ·
NAPA parts would be your best bet.
they have Precision brand u-joints.
What you most likely have is a 1310 series u-joint from the 10 bolt and the 12 bolt uses the larger 1330 series.
If the 10 bolt is a 8.5 the yoke in 99% of the time will interchange.
So you could just swap the rear end yokes.
#5 ·
Thanks guys. Looks like mine measure out for the 1310/1330.
I'll check Napa tomorrow and if no good, I'll order from Summit.
Bob
#7 ·
For future reference in case anyone searches this thread, I found the U joint at NAPA. Part #PUJ353 (Precision) It was $20.29 + tax
This is the 1310/1303 U joint.
Got mine and I'm back to cruising! :hurray:
#9 ·
Hi guys, just so I understand this right.... Im about to put a 12 bolt out of a 67 into a 66 that currently has an 8.2 inch 10 bolt. I cant use the driveshaft(different transmissions-would need a different lenght shaft). So for now, I wanna continue to use the driveshaft out of the car with the 8.2 car. I am not yet sure what the fitment looks like but am I reading correct that one of these universals may be needed to allow me to retain the current driveshaft that was mated to an 8.2 rear, but bolt it up to the 12 bolt with the larger yoke? Thanks!
#10 ·
Yes, a conversion joint is needed.
The 12 bolt should be a 1330 series and the drive shaft a 1310 series
Precision u-joint makes a #253 conversion joint available at NAPA and O'Reilly part stores.
Al
#12 ·
Does this also apply to a 1968 Chevelle going from a 10 bolt 8.2 to a 68-72 chevy 12 bolt?
#15 ·
Not all 12 bolts were 1330's; usually originally produced only behind a big block ,th 400 car.
1310 are 3 1/4" wide ;1330s are 3 5/8 wide.5-134 is Spicer crossover u-joint
