Hi folks,
I am currently trying to get the Brake lights and Flashers working in my 71 Chevelle. Everything else works fine. Reading thru several post here I have followed the suggestions starting at the fuse box thru the bulbs and am now focused on the brake light switch connections, prior to heading for the turn signal switch. I think I have a faulty lead/hot wire (Orange) to the brake light switch. Of all things it appears to be intermittent ... it lights up with my test light and then loses power? The Orange lead at the fuse box to the main harness is good / hot. checked that connection and all looks good.
Any other suggestions on how to chase this? looking for a shorted wire in the main harness is where I am currently at. not having much luck. greatly appreciate any suggestions.
