Working on a Rod End Alternative
6.6K views 58 replies 13 participants last post by  MALIBRU
Hi Guys: I'm working on spec'ing some flex joints that will screw into the aftermarket 3/4-16 tubular rear control arms in lieu of rod ends. I need to nail down the best width to machine the ball flange :cool: so they fit all six of the OEM mounting brackets. Would 2.400" be the "just right" joint size? Bigger? The bore would retain the stock 1/2" mounting bolt to make it an easy swap. 12mm for the G-Bodys. Thanks.
#3 ·
Similar to the Johnny Joint style but with different features that - I feel - offer better technical merit. Besides, JJ doesn't come in the 3/4" thread I need. A generic term is 'flex joint'. Used all the time by the rock crawler guys. I have some feedback that the 2.4" is pretty correct. Anybody else care to comment on this sizing question? I hope to firm-up the order by week's end. Thanks.
#5 ·
Thanks for the info shep 77 :thumbsup: Yes, there are several makers of this joint style, but not with the specs needed for a 3/4" rod end replacement. I ordered some double-adjustable uppers and lowers yesterday. They will come with QA1 XMR & XML chromoly rod ends.
I found that Derek69SS posted a pic of his double-adjustable uppers with the heims and spacers (see frame mount location) here: http://www.chevelles.com/forums/showthread.php?t=156498&highlight="johnny+joint"&page=5 in case you aren't sure what I am referring to.
#7 ·
jj's are available in the 3/4 thread, but only in the 2" version. they dont make a 2.46" ball width for the 2" joints, which means you have to get the 1" stud like i did. way to heavy, but they are done and i dont really want to redo them.
Tim
Tim's right on the money. BTW Tim: Even though you mentioned to me previously that your stock mounts are now modified, your first experience was that the 2.46" was too tight to fit OEM mounts, correct?
#9 ·
A Napa rubber bushing is 2.4" wide. Look at p/n NCP2674219
A GM JJ center is 2.44" W:
http://www.currieenterprises.com/CESTORE/Product569.aspx?id=3052
Already mentioned, the GM JJ ball will only fit a 2.5" rod end, which has a 1" shank. It would be easier for me to make my own arms if it were 3/4" based off the free materials I can get.
#11 ·
the spacer is a possibility, but some extra work. the ballistic fab stuff should be perfect.
the 2.46" width was tight, but not too tight. they slide in and out without problems or force, but .060 smaller wont be too small either. with proper torque specs, the mount will tighten right up against the joint.
Tim
#12 ·
Received my tubular arms yesterday. Built like a tank! Yet heims with spacers = 2.46! It's all press fit, so I can't pop them open right now and inspect. However. the internal bushing holding it all together is at 2.40. Upper arm at axle mount is 2.31 (with powercoat layer). Hmmmmm....
I want to finalize the spec to the machinist Monday and get these new joints made. Would appreciate any additional input by then to run a batch. I will post additional info and pics soon. Thanks for the input so far.
#20 ·
Here's the reply from the race car chassis shop where I purchased:
All of our spacers are 1.5" in diameter now. The size of the spacer will NOT effect anything in the suspension.
My second question was why is one of the six heims polished? I first thought it might be a Midwest Control piece, but they all measure out the same. Newer QA1 XM version? UMI, would you know?
Hey, who you know wants to buy some heims? ...And some spacers? Seriously. Four XMR, two XML.
UMI: I don't want to bash a vendor right now (they are not a site sponsor), but even their own website shows the correctly sized spacers! Additionally, being the nice, courteous, detail-oriented guy I am, I pointed out some $$ product errors on their website they didn't know about. When I specifically requested (and they verified) a 1/2-20 bolt kit, they shipped 1/2-13. I can literally buy zinc G8 course bolts by the pound around here. This is really just too bad, because their upper arms are constructed like a tank and reasonably priced for what it is. Lots of TIG'ing:
Back to the flex joint project. Balls in line to get machined end of next week. Again, want to get a lock on the best width. Would +0.02" be of any significance given the wear on a 40-year old chassis? OEM rubber bushings come in at 2.40". I have to talk more to the machinist to square the deal, get his okay to post details...... and pay him :yes:
#22 ·
Well actually I do think I have the correct answer... and I am pretty sure I am correct here. Over the course of a past few months last year we have noticed the quality of QA1 rod ends to rapidly go down hill. They were coming in with a yellowish tint and the bearings were lose compared to others from the past... some would then come in like they did in the past with the high shine and tight bearing. I contacted QA1 and they didn't really give me answer to why it was happening. I sourced out another rod end brand late last year, the quality of the new rod ends is out standing and the rod ends look great and consistent.
My guess is those are QA1 rod ends because based on your pictures that is exactly what they started looking like for us before we switched brands.
Hope that helps!
#27 ·
zookpr:
I got to examine those seals last week. Initially looks like a no-brainer add-on to street heims, but they aren't sealed at the bolt head. So if water managed to enter at that point, how would it get out? And if it's covered up, you'll never see it rusting and then ruining the bearing and so on... It makes sense to me that the original intent of these seals was for dirt racing. Of course the seals got inspected after each race.
#28 ·
Adding some sort of seal on a street car is better than just leaving them fully exposed. I don't make them or sell them. Just providing some information that some folks may be interested in. As for sealing around the inner diameter some RTV at assembly will provide seal. I'm not concerned about rust - they don't rust. Just want to keep the road elements off them. For me, I have them on some Caltrac style traction bars on a leaf spring street car. But for others that use rods ends, these things may be holding in the rear like in a Chevelle. Yeah, I know you don't need rod ends on the Caltrac style traction bar - just like you don't need them on a Chevelle 4-link. The single degree of freedom bushed ends that someone posted above are fine.
#29 ·
Moving a little closer to finalizing this. A question regarding thread length. Rod ends for 3/4-16 run 1.75". I can bump this to 2.00" to get more engagement.
Many of the exisiting upper double-adjustable arms have this: http://www.midwestcontrol.com/catdisplay_short.php?pg=518
The female depth on 3/4-16 is 1.5". My arm has this adjuster and has an inch threaded in there. Male end is pretty much threaded in with some room for the jam nut.
A 1/4" inch isn't that much of a gain but it's no extra to do it. Going any longer maycause problems on certain bars. Comments?
#31 ·
I ran some calculation based on mild steel as adjusters.
http://www.engineersedge.com/thread_strength/thread_bolt_stress.htm
From the above using this formula for internal thread, Âľ - 16 on mild steel:
3/4" - 16
En max (in) = 0.7159
Ds min (in) = 0.7391
Le (in) = 0.75
n = 16
(Shear Area) An (in^2) = 1.243948724
Shear stress (yield /2) (psi) = 25,000
Shear area x shear stress = Force
Force to strip (lbs) = 31098.7181
So based on a ¾” thread engagement, it will take 30,000 lbs to strip/pull the threads. If I calculated this correctly, this is about the same strength as to what the rod ends are rated to.
#33 ·
bochnak-
I guess I'm not sure if that Midwest piece is what I have or not but it measures the same. As Emil Faber would have said: "Thread engagement is good." Since you brought up the engineering math, what would be the calculated strength of aluminum lower control arms? Here's a guy using these on a late-model Camaro: http://www.jonaadland.com/Z28/Mods/LCA/AluminumLCAs.html along with a technical commentary on strength. This company offers the same thing: http://pavlockperformance.com/content.php?id=84 I'm going venture a guess that the reason they work on the Camaro is due to the torque arm design. The torque arm manages the twisting forces and the links just keep the rear in the wheelwells.
Well, here's the Coleman Racing 18" bar: http://www.colemanracing.com/catalo...catalog/product_info.php?products_id=35&osCsid=adc9543368133211a0cad7b36c57cd86 It's a turn-key piece: direct-threaded, perfect length, light weight and $17 each.
#34 · (Edited)
bochnak-
I get all my material info at Matweb.com. For shear, just divide the yield by 2.
1018 yield - 53kpsi/2 = 26.5ksi or 26,500 psi shear
6061-T6 - 40ksi/2 = 20,000psi shear
In the initial calc I used 25,000 psi. Re-calc for 26,500 is:
33,000 lbs for .75" engagment for 1018
25,000 lbs for .75" engagment for 6061-T6
http://www.matweb.com/search/DataSheet.aspx?MatGUID=1b8c06d0ca7c456694c7777d9e10be5b&ckck=1
My numbers are very comparable to the link you provided. He does not mention engagement, a variable that is important. Also, a great link, thanks!
