boomhauer
Discussion starter · #1 ·
While installing my new intake manifold i ran a bead of gasket sealer across the front and rear areas where the rubber gaskets go. I usually do this and leave the rubber gasket out.I used gasket sealer instead of silicone sealer.Is this going to be a problem?It says its non hardening,for sealing threads and gaskets. 24 hours later i can still stick my finger in it and it comes off on my finger. Should i just yank the intake off now and redo it?
Boom,
For the price of a set of intake gaskets, maybe $10 ... take it off ands use the right sealer. The stuff you have on there will never harden and will end up a mess in the future.
Save
