Got a line on a couple of Ford Windstar cooling fan assemblies for my cooling system upgrade. What is the difference between the 95, 96 and 97 models if any?
i just checked and the link says apply voltage to just 1 tab for LOW and both for HIGH, this is wrong, i know for a fact, done checked it out before i re-installed mine while i was putting the diodes on.... there's another diagram somewhere i remeber white/blue that i'd like to see again though..... i think it needed a few "changes" also.Epistuff said:The wiring is incorrect for which diagram? Yours or the other link I found?
How did you mount a temp switch in a hose?chev-hell said:and the other comes on only when running AND the temp is over 180ish... thru a temp switch in my radiator hose....
