1 - 1 of 14 Posts
Mine does that sometimes and I think that it is because some odd file gets corrupted and will not play nicely in the shutdown procedure. Try hitting control/alt/delete and see what is still left running. The answer may be there. If you try to "end task" and each item it might continue the shutdown procedure. If so, that would point you to the culprit bit of software.
1 - 1 of 14 Posts
