I have a 1965 283 Chevy engine that seems to run pretty good. I haven't actually driven the car, but ran the motor before starting to take the car apart for a body off restoration. I know that driving the car for a while would have told me a lot, but the reason I didn't drive it was that I bought it this winter, there is snow on the ground, and it does not have license plates.
Compression is as follows: four cylinders at 120 psi, one at 130 psi, one at 115, and two about 105 to 110 psi. The engine isn't making any major bad noises. I have no idea if it burns oil or not, but it isn't blowing huge clouds of smoke. The spark plugs are old and looked fairly even in color and wear. None were gunked up with heavy deposits or oil. The car spent about the last 12 years parked, although it was occasionally run for short periods of time.
Does anyone konw what the original factory compression should be on a low horse, two barrel 1965 283?
Before putting this car back together again, assuming the project makes it that far, would it be recommended to disassemble and rebuild the engine?
Although I might have to post a transmission question in another forum, I'm wondering if the Powerglide should come apart before reinstalling it. Again, I have no idea whether it is good or not. Any clues on how to tell if it needs a rebuild without driving the car?
Thanks for your advice,
David
1970 El Camino SS396
and a few projects
David
and a few projects
