when is going to a larger (1 3/4 from 1 5/8) neccesary? is it a hp level or when you feel its neccesary kinda thing? would there be much improvment on a 450 or so hp engine?
I agreeOriginally posted by hoffbug:
These are some other guidelines I have collected..Yes they do overlap.
IMPORTANT NOTE: "IF MAXIMIZING BOTTOM END-MIDRANGE TORQUE AND TOP END POWER IS NOT OF IMPORTANCE.. USE THE NEXT SMALLER TUBE SIZE"
V-8 H.P.output.. Tube size
140-180********1 1/4" OD
168-220********1 3/8" OD
208-308********1 1/2" OD
300-400********1 5/8" OD
380-500********1 3/4" OD
480-580********1 7/8" OD
560-660********2.00 " OD
620-800********2 1/8" OD
780-1050*******2 1/4" OD
1000-1200******2 3/8" OD
PRIMARY LENGTH AND COLLECTOR SIZING ALSO ARE IMPORTANT IN HEADER SELECTION!
Eric how much a different will it make if you use a 1 5/8 shorty header and a 1 5/8 long tube header. That the delimma that I have with my exhaust system. How much tq/hp will I lose over the rpm range up to 6000?Originally posted by Eric68:
An engine may have the same RPM band with a 1-5/8" shortie header and a 1-3/4" long tube header.JMO [/QB]
So why the heck did you buy them dang Hedmans for anyway? Geez, who's the idiot that recommended them to you in the first place . . . LOLOriginally posted by travis g:
Or better yet, a better fitting headerI have headman 1 3/4" headers with 3" collectors...spark plug access on several cylinders is horrible, as is clearance around the steering shaft.
