..and,what tires are you using and what is your 60 ft.? ET too
Agree...don't know if this technique generates the best ET and/or 60' time or not, but it's the most consistent for successful bracket racing. This is what works for me, anyways.mc71454 said:Idle at 1200 (set in the pits using idle screw), foot barely contacting gas pedal. when I see the third amber I push the gas pedal down and go.
Does your track use the old style bulbs, or the new LED's? Also, lowering air pressure in the front tires will slow your reaction times (Makes the tire contact patch longer)Sandy said:Just don't understand how many of you guys can leave at the start of the third amber and not red light ???
My car is consistent at 1.80 sixty foot and I am very careful in staging the same. Have to leave in the middle of the third amber to cut a good light. Just a shade early from middle of amber and she goes red.
How can this be happening ???
10.50 x 28 slicks with 12.5 psi, 4.1 gears, leave at 1200 rpm, no spin, no bog, just goes, but hard as heck to cut a consistent good light in the middle of the amber.
Where am I going wrong ???
How can I get the car to react slower ??
A higher start line rpm won't help enough. Once I get to 2600-2800 rpm, the front end starts extending and I lose valuable front end travel for proper launch & traction. I simply cannot get enough start line rpm to make the chassis react quick enough for the .400 pro tree. Even deep staged and 3000 rpm, the best light I've gotten on the pro treet was a .530...not close to being competitive against .450-.480 lights. A t-brake, higher launch rpm, and shorter front tires are my only chance at quicker lights. I'm now working with tightening the front shock extension to quicken reaction times but must be very careful not to reduce front end travel as the car will then not transfer weight, nor will it hook on the little tire. With the shocks I have, you can easily tighten them so much that there won't be any suspension travel. As an example, out back I currently have the compression/bump set at 8 to 10 clicks (total of 24 clicks) and the back end of the car is nearly rock solid pushing it down by hand. The shocks also have a rebound adjustment as well, again, 24 clicks.Eric68 said:10secbu -- I use the same tires and technique you do to launch and typically cut low 1.5 sixties and 11.0 to 11.teen @ 120 mph ETs. That's with my little SBC and 3540 lb camaro.
When bracket racing I increase the stage RPM to reduce reaction times. Not sure if it would help you to increase your launch RPM to cut a quicker light or not but it seems to work for me.
