What to use on trans input shaft splines?
8.6K views 20 replies 14 participants last post by  gibbons
what ever lube you put on the splines will be slung onto the clutch disc, flywheel and pressure plate. you generally do not want slippery, oily stuff on those surfaces.
you could use a dry film spray, but that won't last long, it just might make it slide together easier.
