Hello eveyone,....
Anyone who's been following my project knows the hell I've been going through. I finally got the valve issue sorted out and now have good compression. And I bought the new set of cables for the batter which got the starter going again....
Heres my current problem... What do you do when your father gets a pencil eraser and metal cap stuck in the number one cylinder of your engine. Yes,... thats right,... he put a pencil in my engine to see the piston rising and when he pulled it out not only the pencil eraser but the metal part that holds the eraser to the pencil fell into the cylinder. I have been trying with the shop vac for days to get the eraser out with no luck. If I have to pull the head again after all I've been through I think I'm going to kill him. What should I do. Is there any way of getting it out without taking off the head. What would the results be of starting the engine,... considering the rubber would probably burn up,... what about the metal.... Please help,... I really want to just get this nightmare over with. Thanks,....
Dan
Dan
