What should my combo make?
1.2K views 13 replies 7 participants last post by  Mikeys69
#1 · (Edited)
What should my combo make horsepower and torque wise along with 1/4?
1970 Chevelle 2dr
406 sbc
Forged Eagle crank
Manley Forged Rods
12cc Dome JE Foged Pistons
Crower Custom Solid Roller-286/302 duration .585/.603 lift on a 108 grind
Out of the box Edelbrock Victor Jr. 23 degree heads-64cc chambers 2.08 intake and 1.60 exhaust Angle plug
Crane 1.6 needle bearing roller rockers
Edelbrock Performer RPM intake with 2-Edelbrock 650 cfm's
MSD Pro-Billet Mechanical Dist. MSD 6al box
Edelbrock Victor Series Water pump
Turbo 350 Trans with 3000 stall
8.2 10 bolt-Eaton posi unit w/ 3.55 gears.
#5 ·
it may make 450+ but won't go anywhere with that 8.2 & 3000 stall conv.
BANG!!!
#6 ·
Yea I know the rear has got to be swapped out eventually...At first this motor was going in my camaro and now since we had the 383 out of the chevelle we decided to slide this motor in as its been on a stand and not ran since 2004...I had a 12 bolt I was going to build for the car but I donated it to my uncle that has a 66 chevelle since he is painting my camaro for me.
#9 ·
Your math doesn't add up here.
12 cc dome
3.75 stroke
64 cc head
4.155 bore
.041" head gasket
zero deck 14.6x:1
.060" negative deck (.101" total piston to head clearance) 12.19:1
Are you saying your pistons are around .050" below the deck?
What does work out at 12.5:1 is the 70 cc chambers, an undecked block, and 12 cc domes. (Vic Jr's come both ways)
