1 - 2 of 2 Posts
Stikman33
Discussion starter · #1 ·
Hey guys, i just did my 12 bolt swap but my diff was already broken in so this is for a friends. Just put new gears and new eaton posi in a 12 bolt going in a 68 elky. What is the proper break in for new gears and posi? Any recommendations on gear oil for a new rear end, posi additive? I have heard that you should take it easy for a little while and vary your speeds and such on the highway, but just how much is necessary and is this the best way to do it. Thanks.
Daniel
Save
Daniel,
I have always used Richmond's synthetic gear oil. As far as break in goes, you should do whatever your gear's manufacturer recommends. Here is Richmond gears recommendation:
"A new ring and pinion installation, especially a high numeric ratio with new bearings, can cause an excessive heat buildup in the rear end and cause softening of the gear teeth and bearings if a break in is not performed.
Street vehicles should be driven at normal street driving speed for approximately 10 miles, then stop and let cool for 30 minutes. Do this 2 to 3 times. Towing vehicles need approximately 200-300 miles of normal street driving before being used for towing.
On circle track race cars make approximately 6 to 8 laps at slow speed, then let cool for 30 minutes. Make 6 to 8 more laps at slow speed, then 2 to 3 laps at full speed, the let cool again for 30 minutes.
Drag cars need only an initial run-in since they are driven short distances and heat is not normally a problem with proper lube and
backlash allowance.
NOTE: If after the above break in is performed, overheating of the rear end is suspected, repeat the final portion of the
break in procedures."
Hope this helps,
Bill Koustenis
Advanced Automotive Machine
Waldorf Md
Team Chevelle #100
Save
1 - 2 of 2 Posts
