slvrchvllss
Discussion starter · #1 ·
Want to change out the transmission fluid on my 70 SS with an M20 4- speed. I figure I have to pump it out by hand since there is no drain plug. :confused: What weight gear oil do I run?? Also, do I use GL-4 or GL-5?? How much do I need as well?? Thanks in advance. :hurray:
I run Valvoline 80W90 in the ST-10. I am pretty sure that is what was run in the M22 as well. I can't help with an exact ammount, I just fill it up to where it's level with the fill plug.
