Weird problems with newly rebuilt 350
1 reading
382 views 11 replies 9 participants last post by  MikeN
Ive put together a fresh 350 for a friends cruiser that also runs a powerglide.
Car was running fine previously with a 307 and the same glide.
350 uses new 461 look heads and a mild Summit 1069 Hyd flat tappet cam 214/214/110
Reusing Summit HEI and 1850 Holley
Engine fired straight away and I ran it in for half an hour. Later we gave it a basic tune and engine sounded nice. 16 inches vacume.
Then we started having problems with the engine cutting out very abruptly as if power to the HEI was cut. The car would also stall and cut out when I put it in drive as if there was zero stall in the convertor.
After a while I decided the occasional engine cut out only happened at low revs, say 1000rpm or below.
We changed the carb to a new 650 Edelbrock and got the same results.
Alternator charging at 13+volts
We put a 12v+ wire direct from the battery to the HEI and the engine still instantly died when we pulled it into gear.
We changed the cap/coil with a new Summit HEI cap/coil
I now wonder if the problem is the body of the HEI, whereby the Ign fails if it drops below 1000rpm, which is what happens if I drop the idle down or pull the car into gear. The engine cut out is instantaneous, not a slow process you would expect if the carb was lean or timing out, too low stall etc.
Also struggling with a pair of new starters, factory new style where after a while of restarts it spins the starter motor but doesnt throw out the gear to engage the flexplate. I notice the rod out the back of the solenoid is plastic as is the arm/lever to throw out the gear. We pull them apart, find nothing then later put them back in the car and they work fine for a while.
#2 ·
Buddy had a 455 Olds built and it would die at very low RPM.
Bore was too tight.
Another friend had old gas in a car and it stuck the valves and seized the engine up.
I have leaned a Quadrajet down to #49 jets (just messing around as a teen) and it would idle at 800 rpm just fine. Put the TH350 in gear and the engine would die.
I had a weird ignition issue that was traced to the wiring harness at the firewall.
#4 ·
Just a few thoughts with the HEI. Make sure you're running the HEI ground strap (GM #1894868). Make sure your engine ground is in good shape. Make sure the coil button and spring in the cap are in good shape and making good contact with the rotor. If all looks good, it wouldn't hurt to swap out the module.
Correct on dist module replacement.
The grease on the bottom of the module eventually goes away due to heat and will cause issues and eventually die. I stopped for a school bus once and when to go and it died. Always carry a spare and the tools to replace a module !!
Not saying you do this, but many sources on the Internet as well as auto parts stores, hot rod magazines, etc mistakenly say to use dielectric grease under the module. I've even gotten a little tube of it with a new module. The right grease to use is heat sink paste, which can also be gotten from computer supply stores. Dielectric grease is greyish/translucent and heat sink paste is white/opaque.
