21 - 40 of 368 Posts
Discussion starter · #21 ·
That barometer is awful. Odds are against you, but good luck. :)
So the car will retain the present torque converter that is uses for the high HP setup?
What rear gearing?
" Odds are against you"
I've heard this from a few others as well. I have a cart full of converters, so this will be optimized, the gear is a different story, 4.56 to answer your question, and I don't really want to change them, this could be a problem.
Since there are so many PP heads out there, the idea that there can be an optimized combo for them is a great way to sell a new line of parts and services :)
Someday I'd like to see an optimized combo for std stern drives in boats. You can't spin those things to fast and they have mediocre exhaust flow through the leg and prop. I think this is another place where PP heads could be used with a combo that yields big TQ at 4,500 or so :D
So I wonder if there is a way to enhance swirl with these heads. That might allow a bit more timing...
The intriguing thing is Somender Grooves. Usually cut across the quench area and aimed at the spark plug. The theory is that in that last little bit of compression stroke, the gases in the quench are are ejected at high velocity toward the plug adding turbulence... Some guys point them towards the exhaust valves... But whatever direction they are pointed, I'm sure they add either swirl or turbulence.
In all cases I've read about, they are able to bump the timing a bit more w/o detonation :)
I realize this is all voodoo, but he does have a patent on this and some pretty extensive testing ...
Here's the link to his patent: http://somender-singh.com/patent/patentpage.html
Discussion starter · #33 ·
Flow test on the un ported 236 heads with a 2.190 intake valve installed. Its interesting to compare these flow numbers with other heads of the muscle car era.
Bad Port
.200 143
.300 205
.400 228
.500 238
.550 Done
Good Port
.200 144
.300 206
.400 238
.500 245
.550 Done
2.190 intake valve, no back cut, 4.310 bore, tested @ 28 inches.
Bad Port
.200 143
.300 205
.400 228
.500 238
.550 Done
Good Port
.200 144
.300 206
.400 238
.500 245
.550 Done
when you open up the port as large as possible I bet they pickup everywhere?
Why do the peanut ports get such a bad wrap? Looks to me like those flow numbers are pretty close to what the stock '60s Oval ports flow @ < 0.500" lift. No factory "muscle car" BBC oval port cam lifted the valves more than 0.500".
Did they ever make a small chamber version of the peanut port? Seems like a great head for 396/402 combos if they had small enough chambers.
