Ran test n tune friday night and the the car was fairly consistant with the changes we were working on. The carb has never had a bogg except when I jetted it down a couple months ago. It was mentioned on here about a lean bog so I jetted it back and the bog was gone. The car has no delay whatsoever usually and didn't have one Friday.
So....Saturday morning I reset all my valves only because it "seemed" as the valves were a little noisy. I am now using a synthetic 5w-30 oil and am now thinking it may have just been the thinner oil after the car gets hot.
My valve lash calls for .020 for both. Last time I set them at .012 cold. Car ran all its bests with that lash setting. This time I set them at .011 cold. Not a huge difference but thought it might make it just a tad quieter.
When I went to start the car it kinda ran crappy when I first fired it up, not real responsive and kinda of a tight feel. Once it completely warmed up it seemed like it ran normal again. However, at the track I had a pretty good bog when I stomped the gas at the track. I raced all night with the convertor up around 2k. This cleaned up almost all the bog but of course killed my 60ft and ET. The car also didn't start right up all night. Usually it fires immediately but I had to turn it over a few times and give it more fuel than normal.
For the most part the car ran the same times that I ran on Friday night but we had more humidity on Saturday and my 60fts were almost a .1 slower. So by that I think the car actually ran better but I didn't like it having a bog and it not firing right up.
Is the valve lash too tight? Only thing I can think of is I ran the car friday night until after midnight and then was out there at 5am setting the cold lash. Surely the engine was considered cold. I am wondering if its possible the engine was still too warm and therefore my .011 lash was too tight.
Any ideas?
FYI. I re set the lash after the first drive with the engine. This is only other time I have checked lash since I have been driving it and racing it. So about 4 months of hard driving.
Any ideas?
