So I recently converted my car from automatic to manual and now I can't even enjoy it. I replaced starter and battery so it can't be those. My problem is sometimes the car won't start at all, sometimes it does and runs fine, sometimes it starts and runs horrible. I'll describ the horrible run situation. It wouldn't be able to run unless I hold down the gas pedal and even then hardly any rpm, if I let out clutch in a gear to try and get it moving it will stall almost instantly as it doesn't have enough power to move the vehicle. Its a 1 year old 290hp GM crate engine, I checked oil levels and its fine. Maybe its coil or carb?? Also I can't check my oil pressure because the sending unit was so big it won't fit anywhere now that my zbar blocked off its only former location. There is also some smoke coming from the exhaust, very faint I can't even tell the colour but I'm reaching out for support as today I got stranded and had to wait 2 hours before someone pushed me back to my house. Made it 6 houses down the street before it craped out.
:sad:
