Maybe I'm not so good at using the search but I can't seem to find a good explaination on why I (and others) have hot restart problems.
First... Battery is 4yrs old 775cca @32° and 12.4v (engine off). With engine running 14.5v.
This should tell me that the alternator is charging.
Second... I just replaced the (+) cable to 2g and mounted the (-) directly to the head using a star washer. solenoid has a heat shield. Starter is a high torque standard delco.
I even tried a N/C momentary switch to turn off the power to the coil, killing the ignition. Still no difference.
What's my next step?
