Ok guys, i have a sometimes intermitent problem. Here is my situation. On my 327 i have and edelbrock 600 cfm carb and a 4 hole spacer, factory fuel pump, HEI ignition, Taylor wires, New autolite 75 plugs, and am MSD 6A box. Here is my perdicament. The car seems to sometimes stubmle at idle, it will idle, but it is weak and i have to turn it up with the idle screw to keep it from dying at lights. When it is demonstrating the idle problem i experience this. In park in my driveway i can sit there and accelerate the motor, and it is very sensitive on the lower rpms, i take it to about 1200 watching the tach the whole time where it jumps all of a sudden about 4-500 rpm. I was going into it very slowly and when it got to that point it decided to jump, hold it there and the rpms stay higher and they bounce around a hundred rpm or so in either direction, you can hear the engine change. As i accelerate more the surging/stumbling effect minimalized until it is no longer noticeable above 3000. When it is at the higher rpms it almost feels like a miss, because it is a very quick blip in the engine sound, not even noticeable on the tach. The car will behave like this in park or driving around town, hot or cold outside. I say it is intermitent because a day ago it decided to start working normally for a couple of hours out running errands, i brought the idle back down to where it normall was and drove around happily figuring it was a blockage or something that had worked itself loose.
I checked the plugs and they look alright, no problems. I read the plugs and the mixture looks alright with no problems. I richened it a bit just to see if it were a lean stumble but it is not that. I adjusted the floats on the carb to make sure that they were in spec. I am going to hook a vacuum gauge up to it this weekend as i will be out of town for the holiday.
Are my weights sticking and then bouncing around. I checked them and put a little lithium grease under the weights to help that if any. Is my MSD box deciding to not work some of the time? So i sound like i have a fuel problem? Filter is clean with no obvious problems. This is really frustrating me and i want to try to figure it out. Any suggestions would be helpful. My BBC won't be done for several months so i want to get this figured out. Thanks
Daniel
Daniel
