My '71 is a street driven car that i'd like to take to the track once i get everything done on it. Im assuming im better off setting initial timing instead of total timing (but im not sure if that would be the best for my application or not). I have an old tune up book that lists what timing should be set to for a stock car w/the stock motor but lets face it, mine isnt close to being stock. Heres all my info, hopefully it helps.
-SB 400 bored 40 over right around 10:1 c.r.
-D.U.I. distributor w/vacuum advance
- Holley street avenger 770 carb w/vac. secondaries
-Trick flow 23* 420 hp top end kit
- Cam 228/234 @ .050
- .480/.494 lift
- TH350 2800-3000 stall torque converter
- Hooker comp headers w/2.5" exhaust through FM 40 series and 2.5" tail pipes
- 3.73 gears
Thanks for all the help guys, hope this is enough information to get things rolling. I have been running this set up for a while w/the timing set from that book, but i think it could have run better. I took the dist. out and had it checked and just put it back in and want to set the timing for good!! Thanks again guys!!!
~Paul
- .480/.494 lift
- 3.73 gears
~Paul
