Like title says, im trying to decide on new trans for strip/ street car.
Brief rundown on car
3000lb 64 chevelle
496 roughly 750hp
270@.050 with 720 lift solid roller approx
390 geared ford 9 inch
D/A coilover with adj anti roll bar
15x30 inch tall tires
full cage
santhuff 200lb front spring with double adj shocks
shooting for 990 naturally aspirated
when I say strip street at most on street it will be driven to local meet and greets and to the strip which is 1.5 miles away. It will be mostly a strip car as I have 3 others for street use.
Im torn between 3 transmissions. And all 3 would make good choices I think
1. powerglide would probably be most consistent and the lightest
2. turbo 400 might induce to much wheel spin off the hit
3. 4l80e. would be nice to have overdrive just in case I do freeway drive it but heavier than the rest and will have same drawback as 400
I do have the car set up for the 4l80, as in tunnel has been seriously modified. but since i set it up course of car has changed for street to mostly strip
TIA for any and all input
3000lb 64 chevelle
496 roughly 750hp
full cage
