Does anybody out there know where I can get a complete trunk carpet kit for my 1966 SS. looking for something that would cover the complete trunk area.
Dear Mr Plum Crazy66, a company known as Custom Trunk Panels makes Pre-made Wood Type Panels to cover Your Trunk Bottom, the Left and Right Sides, the Rear Trunk Latch / Rear Sail Panel plus the Front Vertical Panel Next to Your Rear Speaker Shelve for Your 1966 Chevelle SS. These Wood Type Panels are held in place with a small press fit of all the panels installed. You can use double sided tape or weather strip Glue to install two (2) L Shaped Brackets on the Upper Metal Part Rear Speaker Shelve Panel for Extra Support to hold the Rear Vertical Pre-Cut Wood Panel (Near the Rear Speaker) in Place. You can also Dress up the Front Vertical Panel after You Carpet by using a Large SS Type Emblem which would enhance Your Carpeted Trunk as You first open Your Trunk. The Custom Panel Web Site is Custom Trunk Panels Manufacturing | Product Catalog. I would highly recommend that You Eliminate the Welded Spare Tire Bracket by calling this Vendor to Purchase an Extra Second Bottom Panel so that You can Double Up this Bottom Panel to Space Over / Lay over Your Welded Protruding Factory Spare Tire Bracket on the Right Trunk Side. Next You could either have an UpHolstery Shop install the Carpet of Your Choice on these PreMade Panels or You will have to Carpet these Panels Yourself by using a 3M Type of Spray Carpet Adhesive. See my 2 Attachments Below. My First Photo shows a 1966 Chevelle Black Carpeted Trunk, Second Photo Shows My 1967 Chevelle Red Carpeted Trunk and my Last Attachment is a PDF of Custom Trunk Panels that You to Down Load to Your Computer which has Photos of a 1966-67 GTO install. I Wish You Much Success. Sincerely Gary 396Does anybody out there know where I can get a complete trunk carpet kit for my 1966 SS. looking for something that would cover the complete trunk area.
That's a great diy project. We're about to finish with the Wrangler project with the bumper and winch from 4Wheelonline finally arrived, we'll take in this '67 Chevelle next. Gonna try that cardboard trick, too.I made my own. Used cardboard for templates and plywood for the panels. View attachment 815726 View attachment 815731 View attachment 815734 View attachment 815725 View attachment 815730 View attachment 815728 View attachment 815729 View attachment 815733
Thank you Gary 396, Much appreciatedDear Mr Plum Crazy66, a company known as Custom Trunk Panels makes Pre-made Wood Type Panels to cover Your Trunk Bottom, the Left and Right Sides, the Rear Trunk Latch / Rear Sail Panel plus the Front Vertical Panel Next to Your Rear Speaker Shelve for Your 1966 Chevelle SS. These Wood Type Panels are held in place with a small press fit of all the panels installed. You can use double sided tape or weather strip Glue to install two (2) L Shaped Brackets on the Upper Metal Part Rear Speaker Shelve Panel for Extra Support to hold the Rear Vertical Pre-Cut Wood Panel (Near the Rear Speaker) in Place. You can also Dress up the Front Vertical Panel after You Carpet by using a Large SS Type Emblem which would enhance Your Carpeted Trunk as You first open Your Trunk. The Custom Panel Web Site is Custom Trunk Panels Manufacturing | Product Catalog. I would highly recommend that You Eliminate the Welded Spare Tire Bracket by calling this Vendor to Purchase an Extra Second Bottom Panel so that You can Double Up this Bottom Panel to Space Over / Lay over Your Welded Protruding Factory Spare Tire Bracket on the Right Trunk Side. Next You could either have an UpHolstery Shop install the Carpet of Your Choice on these PreMade Panels or You will have to Carpet these Panels Yourself by using a 3M Type of Spray Carpet Adhesive. See my 2 Attachments Below. My First Photo shows a 1966 Chevelle Black Carpeted Trunk, Second Photo Shows My 1967 Chevelle Red Carpeted Trunk and my Last Attachment is a PDF of Custom Trunk Panels that You to Down Load to Your Computer which has Photos of a 1966-67 GTO install. I Wish You Much Success. Sincerely Gary 396
