Cortez66
Discussion starter · #1 ·
ok...my car never had the trunk divider board, so when i got the new one, i had no clue how it goes in..does the insulation go on the trunk side? or does the cardboard? if the cardboard...black side facing the trunk?
help me im clueless
zach
Zach,
Seen this discussion before, as you can guess there are two "view points" on this. This is what I did and what I believe is correct. When looking in the trunk you should see the black divider board, not the insulation.
To install remove the back seat and backrest (two bolts) and hang the divider board. I had to cut one hole in the board because the prestamped holes did not match up. Then hang the insulation and reinstall the rear seat.
Mike,
The other "view point" is hanging the insulation then the divider board. So when viewed from the trunk side you see insulation, not the board. I've seen a car or two at shows with this arrangement. Although I've seen nothing authorative on how it should be installed, I think it just makes sense to have the board facing the trunk.
