Hi, I just primed some wheels today with some epoxy primer I have had almost a year.I applied two coats and it is still tacky after about three hours.Does activator go bad after awhile or what could be the problem? Thanks for any replies !!
bsmith411 said:I applied the coats fairly heavy, but I allowed about a 10 minute flash time between coatsHeres probably your MAIN problem!!!
All you need a med WET followed by atleast a 30 min flash time. Two wet coats will get the best protection, any more wont gain you anything.
Epoxy is a slow curing product in the first place and you piled on the epoxy. You just trapped in the solvents not allowing them to properly flash off or escape. Now the surface is tacky
