I am putting a muncie together from parts just to do it...I figure I can build an engine I need to be able to do a trans too. I have a complete worn out M20 just sitting around that I am going to put a rebuild kit in first just so I will be familier with how the thing goes together....Anyway I have a good case and a used gm gear set that looks to be in great condition...most of the engagement teeth still look pointed,but I don't know what normal wear is really. It is a 26/32 trans so the gear set is no more than 40 years old..lol Anyway was gonna buy new synchro hubs and sliders but do not know if I need to use torque lock or standard. I can take pics later of the gears and post them. I know a torque lock on a new gear can cause trouble down shifting...or so I've read. With used gears is it usually a safe bet to use the torque locks or does it just depend? will it cause problems if I use them and I don't really need them?
Also are the synchro assemblies found on ebay for $60-$80 bucks each junk? The ones I am refering to do not come with brass just the loaded assembly. I don't want to spend a fortune but don't want to put it together with garbage either.
