Tony,
First of all I am asking this in the public forum so that your reply and my scenario may help others.
I currently have a 505 with AFR 325 CNC Chambered option at 116cc using the standard 18cc SRP Piston for about 10.5 to 1 compression. Also setting on my combo is a Huge Dart Intake and AED ProStreet Dominator pushing through 2" x 3.5 cheapo Hooker headers. The cam is a 60234 Voodoo Solid Roller ( actualy Harold and Dacaman had to straighten it and regrind ) 255/263 at .050 with .680 lift ( .016 lash ) at 110. Pushing through a turbo 400 with a 4400 RPM Pro Edge converter and 4.10 gears on a 28x10.5 but I am Huge so my car weighs almost 3800lbs
Once I finally got my car to hook I have began to notice the lack of TQ compared to other combinations of a similar design out 60fting me even with the nose up. My car has ran a best of 10.18 @ 131.57 but usually traps 130.50 ish using Hoosier Radials and a 1.45 60ft. i dont run my engine up in RPMs shift before 6k usually.
This brings me to the purpose of this post I have began to look at what is mismatched on my car to improve ET numbers in the RPM range I am operating within. It occurs to me I need to do 1 of 2 things run a more aggressive combo that peaks a bit higher and takes advantage of the 325s.
1. Little more compression.
2. Larger Cam ( to take advantage of the 325 ports )
3. Looser stall or go to a more race oriented 8" instead of 9.5
4. lower gear ratio
5. Larger headers
6. turn more RPM through each gear and through the traps with the change to the combo.
Or optimize my current combo to make more TQ in the RPM range i am currently using it.
1. Intake change-the captain insano Dart intake is probably getting efficient about the time i shift. Was still looking at trying the Merlin that is basically a 4150 intake with the Dominator adapter machined in.
2. Depending on intake purchase I might finally be able to provide the coveted apples to apples 4500/Aftermarket tuned Dominator vs 4150 with Aftermarket tuned 1000hp comparo we have all wanted.
3. try some 1.8 rockers to get a bit more lift out of my current combo....
4. Swap to 4150 1000hp setup.
So now i jump on the forums and I see you have these new wonderful heads and I cant help but think this would seemingly be MY holy grail. The first thing to remember is that my car is a pump gas true full interior uncut street car which is very important to me. So now I am thinking.
1. Sell 325s
2. Buy 290's CNC chambers.
3. Ill get increased compression from the change from 116cc to 112cc combustion chambers which should put me about 11 to 1. And yes i remember you TELLING me to aim a bit higher on CR but I was being conservative as I truly like to drive my car around and we almost have it painted so will be doing even more so. Its not a daily driver but i like to fire it up and drive it around town much more than taking it to the strip ( i mainly go just to hang out with my racing buddies ).
3. The 290s would seem to match my current cams net lift of .662 and probably be more efficient across the entire usable RPM range I use along with being more likely to move 3800lbs more efficiently with the conservative power train i have.
4. If they dont make a proper 4500 intake for your new ovals then i do have access to a nice ProSystems 1000HP 4150.
5. Keep my 2" headers and current exhaust as they are probably a much better match.
Those heads would just seem to match my combo better, I really feel like I can stand more TQ and based on metrics from similar cars I am under performing in the first 330ft or so. It just seems like in my mind i would gain a little HP due to the compression increase or keep the current level at the very least while simultaneously increasing TQ and AVG HP across the entire narrow RPM band I use my motor. My goal is 9.99 on 93...... Your new heads have REALLY thrown a monkey wrench into my plans and I very much like the IDEA of them to accomplish my goals. I have not turned a wrench on my engine since i built it and it has served me well so far I have been very happy with it but i would like to hit 9.99 if that means more aggressive so be it ( as i notice my cam is a bit on the small side compared to similar combos that hit the 9s ) but the thought of doing it conservatively with a more efficient combo REALLY appeals to me.......
4. lower gear ratio
5. Larger headers
1. Sell 325s
