The car is running good but when I got home from the Rod Run I decided to check the lash and change the oil. Well I was almost done with the valves when for some reason I decided to take my magnet and drag it through the oil that collects at the back of the heads. Im now glad I did cause I found a couple of pieces of metal. The oil felt a little gritty but not super bad. So I pulled all the shaft rockers and stands and inspected them and all looked good. I removed every spring and checked the retainers, springs, locks and everything is fine.
I dont understand how two pieces of metal got up there. I would think that they could only come from that side of the motor and from somewhere in the head.
Well I drained the oil and found again metal on the drain plug (about 1/8") and then I cut open the oil filter and found alittle but not like covered in it.
So Im going to pull the motor tomorrow and start a tear down to find where the metal is coming from. I did want to pull the motor this winter to fix oil leaks.
Here are a couple of pics of the metal chunks I found.
